OK thanks for reply TehJibba, but my Pandora doesn't load it just stays in blue Pandora screen
Upvote
0
I been having alot off issues with my phone charging too. On my lock screen it says charging but the battery icon is still orange and doesnt have the charging icon. And if im on my phone it wont charge at all. This could be completely irrelevant to the rom but it didnt happen at all before i flashed it so just wanted to see if anyone else is having the same problem
I like this rom but battery sucks i flash super b11 rom i dont have that issue can u look in to that
.... but i was having the same thing happening with titanium when restoring my apps
Before flashing did you have the JB update already or already running a JB rom? Or did you have the original ICS on the phone?
*Edit* If you were going from ICS to this , did you flash the system prep zip in the OP?
I just realized i have the old boost boot animation. Isnt there supposed to be a new one with this rom?
I flashed the system prep
Can't get the transparency for the statusbar to work. Anyone able to get it working??
This update is nice only thing some app i had before when i going back to install said app is not aviable for this phone not compatible
no there isn't I only assumed as it was an option that it might work lol. I can change the color just fine though just no trans sadlyIs there transparency on the stock rom? Ive nevr used it on this phone so im not sure.
Spanish news el nuevo dia and primera hora those 2
Tweakbox>Statusbar>Background ColorOh ok lol. Where did you see the option for it if i may ask ya?
but why with super rom i dont get that issue app not compatible with device
Well I'm out, shattered my screen
