kevinrubio
Android Expert
some don't like me , when i push it, two things happen to me that are negative. 1) no fast speeds
2) battery gets juiced up
You probably have to much going on, on your phone. How many apps do you have? Is your sd card partitioned and running dta2sd?
thats sumtin in the driver I do believe what isaac said. I will get with isacc and Bob to see what they did.My wife and I both have ascends with metro. I put cm7 on both and realized we have the same mac addresses. So I put bobz version on mine and got a different address. Now months later I would like the newer versions of cm7 but I dont know if they have the same mac address or not. I love cm7 could one of yall cm7 genuis please make two versions with diff mac addresses or pull the original mac address from the phone? I am very thankful for all you guys do.
in system/etc/firmware, you can might can edit the macaddress in the nvram.txt, If your mac matches this one:My wife and I both have ascends with metro. I put cm7 on both and realized we have the same mac addresses. So I put bobz version on mine and got a different address. Now months later I would like the newer versions of cm7 but I dont know if they have the same mac address or not. I love cm7 could one of yall cm7 genuis please make two versions with diff mac addresses or pull the original mac address from the phone? I am very thankful for all you guys do.
macaddr=00:90:4c:14:43:19
metro is a pain to get to add ESN's to their network.This is thewring forum but need a metro user to tell me just boughtmy girl an evo on CL paid 100 for it not sure if the esn is good or bad but I can flashto metro either way right? anyone that can help let me know or put this thread where it belongs me buying her this phone is my way of being able to buy myself the esteen or the indulge without any headaches.
I would. Just back up your sd card on to your comp and reboot into recovery go to advanced and select partition sd card. do 512mb and 32 swap. Once partitioned put your sd card into the comp move all your files back, put it back in the phone and reboot. If you flash the 3.0.2.8 recovery img when you make a back up it will back up all your apps on your ext also. Its also recommended that you have a class 4 or higher sd card. Partitioning it will take all your apps off the phone and put them on the sd and the swap will be used to free up RAM. You can also move all your dalvik to the sd which will free up even more room adn essentially make it faster.
If i leave in my sd card when i partition it will it format my card. I'm still new to this. Can the partition and swap be a step added when i flash to 912? If so when or after which step should i do it?
np, I ran up on that working on the wifi for the a2 n figured thats what Bob did lolThank you so much PlayfulGod, I edited the mac address in the file you said and it worked perfectly!! I also have two guys at work with the same cm7 and we have to fight over the wifi, now I can change the mac addresses and solve all the problems. Again, thank you soooooo much!
if you referring the screen off animation no, the ascend has a suckier screenFinally convinced the wife to let me play with her Ascend. Kickass ROM PG. Would the same fix for the screen animations for the OM work here. That would be kickass. Anyways TY yet again.
No offense to any. But by the time you release a build of 2.3.7 Gingerbread, Others and I will have a different phone; since the huawei ascend is getting old. I really don't see why you (PlayfulGod) try to make another build for the Ascend, yes it will be good but the builds already out is good as well. You should spend some time working on the LG Esteem up-coming ROMS.
Was that your way of trying to request him to build for another phone that you want or are getting and a "way" on how for him to make more free time to do so by ditching another phone?
