Xtremedays
Android Expert
Ok... Problems from the start. I bought a used phone and it appears it has been rooted and returned to stock in the past. 4G works so I assume it is OK.
I had a Dinc and installed Unrevoked on it. I'm not sure what all needs to be removed from my PC to make it work but I deleted the 2 files that I am supposed to download for Unrevoked and redownloaded for Evo 4g. Something tells me this isn't enough.
I do not have HTC Sync installed. When I first plugged the phone into the pc, it recognized a 1.0 android device and "installed drivers".
I booted into hboot (.97 version, I believe) and went to USB Hboot as instructed. I went to properties and instead of saying "Android 1.0 device" is says "unrecognized device". I went through "update driver" as instructed and told it the folder... It says, "Windows cannot find a driver for this device."
This is where my rooting adventure ends.
Ideas?
Have you read through the Rooting for Dummies guide? Try and download the drivers linked in the Rooting guide. You might also try and install then uninstall HTC Sync.
