can someone show me or tell me how to use one root access for my computer to my droid to make my phone a 3g wireless spot
so im reading the how to unroot part of this and i tried installing the unrevoked forever s on zip using clockwork v3.0.0.5 and it says:
finding update package....
opening update package...
installing update package...
installation aborted.
should i still repeat steps 5-7? or should i see if S-OFF turns to S-ON after i install the PC36IMG.zip?? thank you so much!
Before you unroot, mind if I ask why? If its to update, you will not be able to reroot yet.
I am at this step in the rooting process:
STEP 6: Let the Rooting Begin!
unrEVOked should begin to do Its thing.
Follow the instructions as they appear in the lower portion of the window.
When the phrase
Hey Guys,
I Just wanted to post the specs of my phone and ask you what I need to download and what is good so far. If you can please look and tell me, id appreciate it.
I would also switch your recovery to CWM 2.6.0.1 or Amon RA 2.3(my preference) as 3.0.0.5 will NOT flash some zip files. The 2 recoveries I listed support both amend and edify scripts while 3.0.0.5 only supports Edify and alot of things are not written in Edify yet.
How would I be able to change my clockworkmod to the Amon recovery? Is it simple or do i have to reset my phone and all? Thanks a ton!
So I rooted my EVO last night after having it for about a year, and I have to say I'm impressed, and very overwhelmed, by the different options available to me now.
I downloaded and purchased Titanium Backup Pro, and it's currently doing it's thing uploading to my new Dropbox account; but while it's doing that I'm trying to figure out what else I can do.
I am still on the original stock rom, and I am not convinced that I want to change it. (at this time) However, I do think I want to update to a better "Kernel." (I don't even know what this means. To me a "Kernel" is something you eat on corn). Basically, I know it's something that will be able to adjust my under/over clocking of my gpu, but I am curious as to if it will change anything at all in regards to how my UI looks and feels? I like my stock 4g, wifi, and bluetooth buttons. Will those be affected?
Can I use this kernel on my stock rom, and it is recommended- SBC for Netarchy's 4.2.2.?
I have thousands of questions, and I would appreciate a "coach" along the way if it isn't too much trouble. I know we need to "read," "read," and "read" some more in regards to learning this stuff, but I get lost at NAND and Kernel, etc.
Any help is greatly appreciated.
Thanks,
Mac
Should I stick with the gingerbread update or should I go more custom? I think ocnbrze suggested mikg2.3 if I am not mistaken. Is it pretty easy to put a new custom Rom on the phone? I have never done it before so I am just a little hesitant. Any help or advise? I have read the rooting for dummies almost cover to cover. Thank you so much!
ok so i would recommend the mikg2.4(new release just dropped the other day) basically go to the http://androidforums.com/evo-4g-all-things-root/284413-roms-kernels-download-page.html sticky and
1.download the file
2.transfer the file over to your sd card.
3.go into recovery
4.make a nandroid backup first (they are your friend)
5.wipe dalvik cache, cache, and data
6.select "install .zip from sd card"
7.reboot
now the first boot will take a bit longer as it has to build dalvik cache so be patient.
hope that helps.
Ok so my phone arrived and I am trying to switch my service to it. I did the ESN swap through the web site. It says since the phone was previously used on the Sprint network there are all these steps I have to do to put my number on the phone. I cannot seem to make them work. The phone did not update when it contacted the network so I need to do the "one touch programming". These are the steps"
At the Home screen, press Menu then tap Settings
Flick up then tap System updates
Tap Update Profile
You will see the message Device Configuration - The network is preparing your service. Please wait. Do not interrupt this process. If the screen goes into sleep mode, you may tap the screen to wake up the phone. Do not hold down the End key, as it will interrupt the process.
Once completed, the phone will return to the Settings tab
Press the Home key
Here is the problem, the phone I bought runs cyanmogen7...I have zero experience with this. When I go into settings there is no tab for system updates so I cannot update the PRL and profile. (There has to be a way, I just cant find it cause I is a NEWB)
So I guess I am asking either where can I do this in this ROM or is there another way to activate this quickly. Would it behoove me maybe to load up MikG on the phone and do it from there since that is a GB Sense based ROM and the one I plan to flash anyways?
As per usual, thanks in advance for all the help![]()
