mikevo
Member
Ok so my phone arrived and I am trying to switch my service to it. I did the ESN swap through the web site. It says since the phone was previously used on the Sprint network there are all these steps I have to do to put my number on the phone. I cannot seem to make them work. The phone did not update when it contacted the network so I need to do the "one touch programming". These are the steps"
At the Home screen, press Menu then tap Settings
Flick up then tap System updates
Tap Update Profile
You will see the message Device Configuration - The network is preparing your service. Please wait. Do not interrupt this process. If the screen goes into sleep mode, you may tap the screen to wake up the phone. Do not hold down the End key, as it will interrupt the process.
Once completed, the phone will return to the Settings tab
Press the Home key
Here is the problem, the phone I bought runs cyanmogen7...I have zero experience with this. When I go into settings there is no tab for system updates so I cannot update the PRL and profile. (There has to be a way, I just cant find it cause I is a NEWB)
So I guess I am asking either where can I do this in this ROM or is there another way to activate this quickly. Would it behoove me maybe to load up MikG on the phone and do it from there since that is a GB Sense based ROM and the one I plan to flash anyways?
As per usual, thanks in advance for all the help![]()
I'd call sprint anyway to make sure it's programmed correctly. Also have them do a refresh on it and send another activation code to it I've spent the last 2 day not being able to make calls and send text messages. My phone was used by someone else too. I had to call twice about this. Its been 24 hours and no problems.
