Xapk wtf
- By ocnbrze
- Ask a question
- 3 Replies
why not use google find my phone?
its not a program but something you can do on a browser.
I say just keep anything,It is a l0ve hate marriage with th0se, I had them f0rever ag0 and if y0u c0uld g0 with the 0n screen and just tune them t0 y0ur adjustments, s0metimes it is n0t ab0ut the hearing aids, just where y0u stand 0r sit s0metimes and always v0lume d0wn.Thanks, the App (MyPhonak) has no such controls, at least in conjunction with this Phonak model. There are settings for my hearing, such as "restaurant" and "television".
I d0 n0t think s0, if y0u simply burn an exfat 0n y0ur drive then it is smaller bat if y0u burn it, 0r unzip it, if y0u wanna be tech 0n it, it is much smaller, s0 p0werful it can burn an entire wind0ws device in a heartbeat, I recently just use my usb stick t0 burn wind0ws t0 fix up my passw0rd pr0blem..I think they're all smaller than that. I have no idea if Android uses exFAT or what. Isn't it different for computers?
ok, now that makes sense.I am following the Motorola instructions to set it up to not lock.
I am working at getting rid of all the junk that has the phone thinking it knows what I want to do better then I know.
I hear what you are saying and understand. I felt and still feel that something as simple as setting my phone to stay unlocked when on my Wi-Fi should work. My 8 year old Sony has been doing that successfully for 8 years. Could I say, "This ain't rocket science"?
Thanks.
Overflow?now check out the widgets options
on the home screen tap on the overflow icon to the right of the search bar
i dont use google, but there used to be a setting that made it so that approval had to be given before apps could be downloaded or purchases madeAI suggested using App Lock found under settings > Security and privacy. However, I do not find the setting on my Samsung S21 Ultra. An alternative was to search for an app locker from the play store. The suggested app was AppLock. Both methods require a pin, password or fingerprint to access the apps that you choose to lock.
