youdoofus
Android Expert
Yeah I had that till I had to get rid of direct tv...time warner now, grrrrrrr
dood, TW is the best!! soooo kidding lol i cant believe that they have such a low speed in your area... you have my sympathy man
thats what im looking for now
??? I'm a bit confused.....I have yet to hear of forum member finding love here.
hold on before you unroot. go to your app drawer, do you have the superuser app? if you do click on it and see if titanium backup is allowed access. if not, then click on it and allow it access. you shoud be good to go after that.
What app do you mean the one that you can donwload it from the market or the superuser permission app y its the first i cant install it sais installation unsuccessfull and if its the other i have titanium backup allow also as busybox and terminal emulator
Thanks for answering so quick![]()
He's talking about the superuser app. Maybe uninstall it first and then reinstall it from the market and then open TB.
i cant unistall it because it isnt installed i cant install it
Thanks so much to every one i just reinstalled like 3 times and it worked thanks by the way is there any rom you recomend thanks
STEP 1: TURN OFF DEVICE
Power down the device by holding the POWER button for 2 seconds. Allow it to shutdown completely. Wait about 10 seconds before next step.
STEP 2: BOOTLOADER MODE
Hold down VOL DOWN + POWER until device boots into a White Screen.
Move to BOOTLOADER by using the VOL DOWN toggle and select by using POWER button. The device will now boot into Recovery mode.
You should now see something like this when it fully loads.
SUPERSONIC EVT2-3 SHIP S-OFF
HBOOT-0.97.0000
MICROP-041f
TOUCH PANEL-ATMEL224_16ab
RADIO-2.15.00.09.01
Aug 19 2010, 14:29:08
Hey guys,
I finished the ROOTING process and now at the part where I make sure I successfully rooted before I continue.
It says to move to BOOTLOADER but I dont see anything on the white screen that says BOOTLOADER?? The only options I have are FASTBOOT, RECOVERY, CLEAR STORAGE, SIMLOCK, AND HBOOT USB. What do I click on to make sure its rooted?
Thanks.
You are in bootloader. It will probably say bootloader towards the top. Do you see the s-off information?
Being a cardinal fan you will like this. Link
Ah, yeah I realized after I posted that and now I see the S-OFF.
Thanks for clarifying that though.
That Cardinals setup is pretty sweet. I'll have to look into that after I finish the rest of the process (Doing the NAND backup now).
no problem. you know where to ask if you have any questions.
Good deal. Sounds like you are good to go. As soon as you do that back up and flash a custom ROM of your choosing, backup that ROM and delete your original nand because you will never use it again.
PS...Just hit me up when/if you want some of that cardinals setup.
So Do you know if any one has had problems with the batteries heating up and going dead in less then 30 minutes? I rooted per your help a couple weeks ago...everythign has been great....then yesterday morning, my phone died at work, right when i got there!!! I had it plugged in all nite! Anyway, i have an extra battery, thinking it was just a faulity battery....well the old battery is doing the same thing!!! Gets very hot and dies quickly!!! I'm guessing it had something to do with rooting??? It's a new phone.....idk! Help please!!!!!![]()
I'm somewhat lost already. I'm trying to download myn's warm twopointtwo from this [ROM] Myn
